I burnt this dvd (files already authored) at 2.4x and watched it on the standalone dvd player and the audio was outta sync, so I checked it with my comp's dvd player and the files are in sync on the comp. Any idea why this might be ? This happened before when I converted rm files to vcd using winavi and authored with Ulead dvd studio.
What did your source files start out as and what program was used to author. What was the audio format? Need more info please. What burning app and did you try different DVD media and another DVD player to see if you get the same result.
I'm not sure, when I got the files they were already authored.. I just had to burn and I used nero to burn, only one of my dvd players can play burnt dvds so I could only try on one. I havn't tried a diff media but I'm sure it would be the same result. Not sure what audio format, how do I find that out ?
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:56 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Audio out of sync 5 seconds - DVD ripped with DVD Decrypter + AutoGK :(
By dtel in forum DVD RippingReplies: 20Last Post: 25th Apr 2010, 04:01 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 05:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17
