can someone help me plz when i try and copy a dvd all i get is
t5his error
black check command error
can some one help
got 2x piioneer 105 and it will only let me copy at 1x dont no why
Results 1 to 11 of 11
Did you update the firmware for the drive at any time. Also try backing up NERO to a earlier release around Sep to see if that might help. Getting the same result with different brand of media? You are going to need to do some trouble shooting to determine if the problem is hardware, software or media. I would bet it is related to hardware and then software.
yes i did update to v1.30 it did work but it would only let me copy at one speed but if i take it out of my computer and put it in a other computer it works fine at 4x ive even formatted my computer still the same how
do i downgrade my pioneer plz can u help me thanks -
Could be your BIOS settings. Check them out. If it works in one it has to work in another. Reset to default and then to your preferred settings. Maybe upgrade...
thanks m8 i will try that and see if that works could it be that like
Check your IDE settings under device manager. Make sure it (the drive) is runing in Transfer Mode (UDMA Mode 2 and not PIO mode. You can find this under the primary or secondary IDE channels, "Advanced Settings", whichever one your drive is connected to.THis can cause the drive to write slower also.
device 0 its a pioneer a05
device type-auto detection
transfer mode-ultra dma mode 1
device 1-its a pioneer a05
pioneer dvd-rw dvr-105
driver date 7/1/2001
driver version-5.1.2535.0 -
don't need to downgrade your FW. 1.30 is just fine for 4x burning (works for me). Roll up your sleeves and get down to how different your setup is on both PC's. What makes it work on one and not the other?
If your PC was formatted then there is only 1 thing that remained the same: hardware setup. Move it to a different cable position, check your jumper settings. Check, upgrade (flush) your BIOS (!), viruses do screw things up in BIOS. Google for your errors and symptoms. The answer is usually much simpler the you would expect... -
thanks proxyx99 for all your help
i just need it to work till next week iam getting a new pc
it works in a other computer
i can copy cdrs at 16x and there work fine but not dvds it just fails right away with that same error all the time
one of my wrighter is under cd rom now in c:/ drive the other says dvd-r
thanks for yor help proxyx99 -
If you have dropped DVD writing ability but CDR functions OK then your drive is toast. Not a big deal. New drives are faster, better and cheaper. A week ago one of my 19 inch monitors has died (have 3). I was upset. A friend gave me a store address for a quick replacement (refurbs). Went there and bought brand new, never used return 19 inch flat IBM trinitron for 100 bucks (I just love CRT's). What a blessing. I told my son that it could not have happened at a better moment. There's always a bright side.
i know proxyx99
well i got them both working again
but there only copy at 1x but that will do me till next week
whats the best wrighter to buy now like m8
just copeyed a dvd movie at one seed and it workd fine
and what about copying dvds at 8x speed do there work fine copying them at 8speed or is it just a waste of time
and thanks for your help m8
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
