Is it possible to burn a DVD-R in VCD or SVCD format, thereby fitting several hours of video on one disc, and playing back in a DVD player? This assumes that the DVD player can play back normal DVD-R, VCD, SVCD etc. Any help would be appreciated, I've asked around but no one knows for sure.
you didnt do good enough SEARCH of any of the previous posts. in short NO, you will have to extract the movie out of the VCD/SVCD and reauthor in DVD format.
VCD? Yes.
You can put VCD files on a DVD-R and get several hours on a disc by doing so. The audio will have to be resampled to 48KHz ([S]VCD uses 44.1KHz) but consumer DVD authoring programs typically handle that conversion for you.
SVCD? No.
DVD can handle a variety of resolutions, but 480x480 isn't one of them. The video will have to be transcoded to 352x480 or 720x480 in order to be DVD compliant, in addition to resampling the audio to 48KHz.
Safest Bets (if DVD conversion is anticipated):
XVCD (352x240, up to 1.8Mb/S video, 48KHz audio)
XSVCD (352x480, up to 2.4Mb/S video, 48KHz audio)
Both will look better than their [S]VCD counterparts, and will be easy to migrate to DVD in the future.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
