  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    How much video in GB terms can you fit onto a dvd+rDL before you go over the limit? I know dvd+r is only like 4.3GB but what is it for DL
    What We Do In Life, Echoes In Eternity....
    https://www.videohelp.com/dvd#dvdsizes
    DVD+R DL = 8 547 993 600 bytes ( 8152 MB )
    DVD-9, holds around 8 540 000 000 bytes and that is 7.95 computer GB. DVD+R supports this format. Also called Single Sided Dual Layered. This media is called DVD+R9, DVD+R DL or 8.5 GB Media.
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    well damn....I just made a DL of home movies...came out to 8.45, is there anyway to shrink this without have to re-edit out some stuff?
  4. There is nothing illegal, until you get caught!
  5. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    thanx
