am having problems copying non-protected dvds using the nero express
(nero 6 ultra) on my sony drx-500ul. I am able to have a image of the dvd accessed, however, when the writer tries to burn I keep getting a message that reads "burning aborted" or invalid track list, if I use burn ROM. I have tried to reslove this situation with the nero tech support but they keep telling me its a media issue but I am using sony rw. Anyone who can help me I would appreciate the assistance and will provide any information necessary. I have kept the error logs and will post if necessary. I run windows 2000 professional and have all the specs necessary to run a successful burn. I suspect a driver program. Any suggestions to resolve this problem are welcomed. TIA
here is the erroe message I keep getting:
MS
1A23-0006-7130-1481-8270-7387
Windows 2000 5.0
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <SONY DVD RW DRU-500A> Version: 2.1a - HA 3 TA 0 - 6.6.0.8
Adapter driver: <> HA 3
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SONY DVD RW DRU-500A >Version: 2.1a - HA 3 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 54098H8 DAC1 Pnp680 Port 0 ID 0 DMA: Off
DiskPeripheral : Maxtor 6Y080P0 atapi Port 1 ID 0 DMA: On
DiskPeripheral : Maxtor 6E040L0 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : Lite-On LTN483S 48x Max atapi Port 2 ID 0 DMA: On
CdRomPeripheral : OPTORITE CD-RW CW5201 atapi Port 2 ID 1 DMA: On
=== CDRom-Device-Map ===
Lite-On LTN483S 48x Max G: CDRom0
OPTORITE CD-RW CW5201 F: CDRom1
SONY DVD RW DRU-500A H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 57671680 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 383MB (392740kB)
Free physical memory: 198MB (202844kB)
Memory in use : 48 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.3.2005
===== Disc-Copy over image - 1st step : Copy to image ...
6:58:04 AM #1 Text 0 File Reader.cpp, Line 127
Reader running
6:58:04 AM #2 Text 0 File Writer.cpp, Line 122
Writer Image Recorder running
6:58:04 AM #3 Text 0 File DVDCopy.cpp, Line 279
DVD Track-Information from source disc
S01 T01 Con 0x14 Start 0 Len 1930752 (gap 0) Blank 0 Res 0 Dmg 0 Open Trk 0 Mode TRM_DATA_MODE1 (0)
6:58:04 AM #4 Text 0 File DVDCopy.cpp, Line 382
Max -1 tracks of 1 allowed to copy
1: 0 - 1930752 = 1930752, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options)
6:58:04 AM #5 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
6:58:04 AM #6 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2621439 (582:32.39, 5119MB)
Last address to be written: 1930751 (429:03.26, 3770MB)
6:58:04 AM #7 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
6:58:04 AM #8 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: Image Recorder;
CD type reading failed
ATIP Data: ?
6:58:04 AM #9 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
6:58:04 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - Data (mode 1))
2 indices, index0 (150) not provided
original disc pos #0 + 1930752 (1930752) = #1930752/429:3.27
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1930752 blocks [Image Recorder]
6:58:04 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [Image Recorder] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3954180096, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1930752 | lead-out | 1 | 0x41 | 0x00
6:58:04 AM #12 Phase 120 File dlgbrnst.cpp, Line 1832
Creating the image for burning
6:58:05 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
8:05:31 AM #14 Text 0 File WriterStatus.cpp, Line 116
< Image Recorder > start writing Lead-Out at LBA 1930752 (1D7600h), lenght 0 blocks
8:05:32 AM #15 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
8:05:33 AM #16 Phase 121 File dlgbrnst.cpp, Line 1832
Creating Image completed successfully
===== Disc-Copy over image - 2nd step : Burn the image ...
8:05:54 AM #1 Text 0 File Reader.cpp, Line 127
Reader running
8:05:54 AM #2 Text 0 File Writer.cpp, Line 122
Writer SONY DVD RW DRU-500A running
8:05:54 AM #3 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x40
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 3954180096
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=00:00.00 ( 0) RecDep=0x00
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=00:00.00 ( 0) RecDep=0x00
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=429:03.27 ( 1930752) RecDep=0x00
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <C:\Documents and Settings\Administrator.OEMCOMPUTER\My Documents\TempImage.nrg>
8:05:55 AM #4 Text 0 File Burncd.cpp, Line 3153
8:06:10 AM #5 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2298495 (510:46.45, 4489MB)
8:06:10 AM #6 Text 0 File DlgWaitCD.cpp, Line 271
8:06:10 AM #7 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: SONY DVD RW DRU-500A, Media type: DVD-RW
Disc Manufacturer: SONY00 - 0000U9
Disc Application Code: 64, Disc Physical Code: 214
8:06:10 AM #8 Text 0 File DlgWaitCD.cpp, Line 433
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW.)
8:06:10 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
0: TRM_DATA_MODE1 (1 - DVD-ROM)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1930752 blocks [SONY DVD RW DRU-500A]
8:06:10 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [SONY DVD RW DRU-500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
8:06:11 AM #11 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 1x (1,385 KB/s)
8:06:11 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 2609
8:06:11 AM #13 Text 0 File DVDR.cpp, Line 2194
Recording mode: Sequential Recording Mode
8:06:11 AM #14 Text 0 File Mmc.cpp, Line 21235
Set BUFE: Power-Burn -> ON
8:06:11 AM #15 Text 0 File DVDR.cpp, Line 2340
Start write address at LBA 0
DVD high compatibility mode: Yes
8:06:11 AM #16 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-RW (3), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:06:23 AM #17 Text 0 File Cdrdrv.cpp, Line 1287
08:06:23.595 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:07:44 AM #18 Text 0 File Cdrdrv.cpp, Line 1287
08:07:44.351 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:08:01 AM #19 Text 0 File Cdrdrv.cpp, Line 1287
08:08:01.606 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:08:18 AM #20 Text 0 File Cdrdrv.cpp, Line 1287
08:08:18.661 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:08:35 AM #21 Text 0 File Cdrdrv.cpp, Line 1287
08:08:35.815 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:08:52 AM #22 Text 0 File Cdrdrv.cpp, Line 1287
08:08:52.870 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:09:09 AM #23 Text 0 File Cdrdrv.cpp, Line 1287
08:09:09.925 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:09:26 AM #24 Text 0 File Cdrdrv.cpp, Line 1287
08:09:26.989 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:09:44 AM #25 Text 0 File Cdrdrv.cpp, Line 1287
08:09:44.134 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:10:01 AM #26 Text 0 File Cdrdrv.cpp, Line 1287
08:10:01.088 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:10:18 AM #27 Text 0 File Cdrdrv.cpp, Line 1287
08:10:18.243 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:10:35 AM #28 Text 0 File Cdrdrv.cpp, Line 1287
08:10:35.307 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:10:52 AM #29 Text 0 File Cdrdrv.cpp, Line 1287
08:10:52.452 - SONY DVD RW DRU-500A\H3 T0 : Queue again later
8:11:00 AM #30 SCSI -500 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x09B80000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x01 0x72 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
8:11:02 AM #31 SCSI -1114 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x09EE0600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x29 0x00
8:11:02 AM #32 CDR -1114 File Writer.cpp, Line 311
Reset occurred
8:11:02 AM #33 Text 0 File ThreadedTransfer.cpp, Line 228
8:11:03 AM #34 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
8:11:03 AM #35 Text 0 File DVDR.cpp, Line 2603
EndDAO: Last written address was 94911
8:11:14 AM #36 CDR -1033 File WriterStatus.cpp, Line 167
Drive not ready
8:11:14 AM #37 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
8:11:14 AM #38 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 1x (1,385 KB/s)
Existing drivers:
File 'Drivers\CDUDF.SYS': Ver=6.1.1.40 , size=263072 bytes, created 12/1/2003 1:46:22 PM
File 'Drivers\CDR4_2K.SYS': Ver=6.1.1.40 , size=62672 bytes, created 12/1/2003 2:46:22 PM
File 'Drivers\CDRALW2K.SYS': Ver=6.1.1.40 , size=24698 bytes, created 12/1/2003 2:46:22 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.38a, size=16288 bytes, created 4/18/2002 1:02:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
More information on my problem: After beging to burn a disc, perhaps 2-3 minutes of burning the dvd "reset occurs". This effectively aborts the burning program and the burning stops. Can anoyone tell me what "reset occurs" means and how I can address it.
Sony HDCAM HDW-500: Channel Condition
By nicholgh in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2011, 12:36 -
Coping VHSC tapes to DVD+r, lost content due to white noise
By PanMan in forum Capturing and VCRReplies: 2Last Post: 25th Sep 2008, 21:54 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43 -
help Drx-710ul Doesnt Recognize Dvd+r
By aqua in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2008, 23:57
