    Feb 2005
    Hungary
    hi i left gknot. i think i could get better result manually..
    well iam using:
    dvd decrypter + dvd2avi
    then:
    i make an avs file:
    mpeg2source("movie.d2v")
    crop("y1,y2,-x1,-x2)
    lanczosresize(new,resolution)
    i tried lanczosresize and lanczos4resize its the same result i think.
    iam making 2CDs rips pass1 config is:
    Global TAB:
    Motion Search: 6 - Ultra High
    Quantization type: MPEG
    FourCC used: XVID
    Max I-Frame interval: 300
    Min I-Frame interval: 1
    enable lumi masking: NO
    enable interlacing: NO
    Quantization TAB:
    Min i-frame:1
    Max i-frame:31
    Min p-frame:1
    Max p-frame:31
    Min b-frame:
    Max b-frame:
    (all setting is gray, i cant change them)
    Two Pass TAB:
    i-frame boost: 10%
    discard first pass: yes
    dummy 2nd pass: no (grey)
    curve compression: (all grey)
    high:0
    low:0
    bitrate playback:240
    payback with bias
    fist pass stats: its okey
    Alt.Curve TAB: all grey
    Curve agression: medium
    high distance:300
    low distance:300
    automatic min relativle quality: enabled
    strenght: 50
    min quality: 50
    automatic bonus bias: enabled
    these arent grey:
    max bitrate: 10000
    max overflow improvement: 5
    max overflow degradation: 5
    Debug TAB:
    automaticly detect optimizations
    CBR options: (all grey)
    reaction delay factor: 16
    averaging period: 100
    smoother: 100
    done.
    2nd pass setting are the same, i use Xvid 2nd pass Int. and i just set the file size, no change in advance settings..
    now you know my settings
    the question is how can i make sharper rips? so sharper lines in the image
    lanczosresize and lanczos4resize its the same its cool but i've seen rips from some rls groups with much more better quality.
    someone told me that i should use MPEG Custom, but i wont do that because my DVDplayer (Yamada 6700) wont play that 100%
    please suggest me some other things. some filters or dunno
    iam using avisynth+vdub
    thanks in advance:
    blas
  2. Alot of the settings were greyed out because those are the 2nd pass tuning options. Try and lower your quantizers to 1,6,1,6 on the second pass. The first pass uses 2 across the board to analyze. Use perfectXviD to read your stats file for proper Curve agression distances. Make sure the movie size is calculated properly. There are a crap ton of guides here and on other sites. You need to experiment with other guides and come up with your own conclusion. Oh ya, experiment with a small clip like 5-10 minutes worth, it will be alot more efficient.
    Dec 2004
    Australia
    If you have an avi that you think looks nice you can check out what quant matrix was used with MPEG4Modifier.
    Feb 2005
    Hungary
    "Use perfectXviD to read your stats file for proper Curve agression distances."
    i opened the 1st pass video.stats there. what, or how can i change anything there? i mean whats that interval etc. i have absolutly no idea howto make proper curve agression.
    thanks in advance.
    Feb 2005
    Hungary
    celtic_druid:
    i checked an internal 2cd xvid rip, that has very good image.
    the result was:
    Pixel Ar: Square Pixels
    Packet Bitstreams: NO
    Packed bitstream: No
    QPel: No
    GMC: No
    Interlaced: No
    Aspect ratio: Square pixels
    Quant type: H.263
    I-VOPs: 1640 (1,74%)
    P-VOPs: 45841 (48,58%)
    B-VOPs: 46878 (49,68%)
    S-VOPs: 0 (0,00%)
    N-VOPs: 0 (0,00%)
    Max consecutive B-VOPs: 2
    1 consec: 55,71%
    2 consec: 44,29%
    i dont know whats these..
    well i used H.263 for a 1 cd rip and it was unwatchable
    very crappy image.
