before I start explaining my problem I want to say that I searched the whole forum and find number of topics on this issue but none of them helped me, so here i am:
I downloaded a subtitle in RAR format and when I opened it up it contained a IDX and SUB file, but none of them worked with the movie.
In IDX file: there was only numbers of when should the line appear, but no texts.
In SUB file: the was nothing but a bunch of encoded texts.
I have tried playing it with ViPlay, Windows Media Player 9 and Winamp 5.3
I also have VobSub and FFDshow installed.
here's a exact table of files I downloaded, you can download the IDX and SUB file by clicking them:
http://ashole.zendegihamine.com/movie_sub.html
thank you guys in advanced
Results 1 to 9 of 9
i put them in the same folder but still no luck
as i said before when i open the IDX file there is only times of when should the lines appear but there is no subtitle. and when I open SUB file there is nothing to read. if it's no problem for you plz download the SUB and IDX and see what can we do with them. -
ok... i got it to work with Classic Media Player.
now is there anyway to convert those subtitles to a normal text subtitle, say SRT or plain SUB for example? -
The IDX is an index and the sub contains the original bitmaps from the DVD.
Try SubRip to convert.
Media Player Classic links against the same libs for subtitles as VSFilter/Directvobsub by the way. -
Works fine here (best I can remember).
You weren't trying to load it as a textsub were you?
File-->Open VOB's-->open IFO and then open the idx. You can then start the OCR process. -
well thnx... got it working with Subersynch
thnx again guys
"That's me in the corner, that's me in the spotlight, losing my religion"
downloaded SVCD2DVDv2.5.zip won't open
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Aug 2011, 16:48 -
mpg won't stream until the entire thing is downloaded.
By flycast in forum Video Streaming DownloadingReplies: 1Last Post: 19th Dec 2009, 23:23 -
Won't play whole downloaded movie.
By amyyo9 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Dec 2008, 00:20 -
Some WMV files won't stream, but play fine if downloaded
By DVantrease in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2008, 14:49 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 06:31
