Following on form an earlier post.
I am now getting extremely frustrated. All I want to do is put an avi file onto a DVD.
The avi file is 696 mb. I first convert this with TMPGenc, to dvd format. Thing is, the file then becomes too big for a 4.7gb dvd, due, to the size of the audio file. (over 1gb)
I then tried it in Canopus procoder - same again. Too big.
I tried to load the coverted files into dvd shrinker, but the tool does not see the files????
Finally, tried film machine. All goes well with this, unitl it gets to the bit where it needs to locate Canopus procoder for the video conversion. It tells me "no sources found". Which I cannot understand, as I have pointed it to the right folder, AND ...I have used it before on smaller avi files, with no problems.
Basically, it seems that I need to get the audio file smaller. I tried BeSweet on the converted file, but, hey, it does not see it?
Please help. I'm sure this is a fundamental exercise, but it is a nightmare.
"Manchester, so much to answer for"
Do you calculate the video bitrate? or do you just default bitrate settings?
And author the dvd first(output the dvd to a dvd folder) and then use dvd shrink to shrink it. But I recommend that you encode correct first instead of shrinking.
Problems with an avi to MKV conversion
By Paxmilitaris in forum Video ConversionReplies: 0Last Post: 21st Oct 2011, 14:11 -
DVD to avi conversion problems
By carlmart in forum Video ConversionReplies: 6Last Post: 19th Apr 2011, 14:01 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
Having problems with my .MKV conversion (to .AVI)
By triptiks in forum ffmpegX general discussionReplies: 2Last Post: 16th Jul 2008, 22:29 -
By olson311dude in forum Video ConversionReplies: 14Last Post: 9th Oct 2007, 04:27
