  1. Hello there. I have an .avi movie that has the following properties:
    23.976 fps, 576*320 (16:9), DIV3 = DivX v3 MPEG-4 (Low-Motion), Supported
    This movie has perfect sound sync, but is playing Back on my PC monitor with a very noticable jitter. Is there any program I can use to reencode the movie to play back at 25.0 fps (which I assume would get rid of the jitter?
    Thanks for any help, Cheers Chris
    Change to 72 hz on your monitor(72hz/24fps= even) and use reclock.
  3. Thanks Baldrick, I will try this then. i currently have my PC monitor set at 85hz. Cheers Chris
    Intel P4 2.8c 800 FSB
    MSI Neo2 i865 Mainboard ( 6728 ) Rev 1.1
    Kingston 256 Mb RAM x 2 (Dual Channel) Gigacube R/ATI 9600 Pro VIVO
    WinXP Pro (All SP's and fixes) applied
