i bought a few 50 pack spindles back when 8x burners just came out, the media was 4x richjpn i think +r
my last few times they have been prodisc r03's
i got them for dirt cheap only reason i bought them, they started with good media to get a loyal customer base then crap media now i have heard to many times![]()
Results 31 to 50 of 50
I learned my lesson on their cd-r products.
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
I've used both Memorex DVD-R (ProDisc, they turned out to be) and CD-R for some time now, and never have a problem.
My main issues in the past were with burning software, but I've since switched to Sonic products only, and everything works beautifully. -
Memorex is the sh!ttiest of the SH!T. I bought a pack of 50 and a pack of 50 Ritek. Now mostthe movies I burn with Memorex are either unplayable, skipped, or freeze while play with my standalone player. No label were used just Sharpie. Check this, all the ones I burn with Ritek are running perfectly. That was the last time I ever bought Memorex and I got first hand experience. I tried to reburn the ones on Memorex to Ritek instead of having to rent all the movies but it's so crappy that even my DVDrom were having problem reading it. No offense but thanks to all the newbies for recommending Memorex when I first got into this ripping/burning DVDs that I now have a bunch of useless movies. Save yourself the headache and go with ONLY Ritek or Taiyo Yuden
Originally Posted by crashnburn
Just look at the media reviews, Memorex uses Prodisc, Fujifilm, CMC, MCC, Princo, MBI, Ritek, TY, TDK, Philips, RICOHJPN, Infodisc.
I've used all of the above media codes from one brand or another except for MBI, and I've heard mostly good things about them. Be specific, don't say Memorex is shit, say 'xxx media is shit'. Only media above that I've not had very good luck with is Princo, the rest have been fine for me.
Don't say 'Memorex is shit', you're only labeling almost every media made as crap if you say that. -
Memorex is like a box of chocolates, you never know what you're gonna get.
With Memorex CD-R's, it's pretty certain you're gonna get either CMC Magnetics or Moser Baer (both crap). DVD+-R could be different, but by all means avoid Memorex CD-R's like the plague.
I got burned when I bought a 3 pack of DL memorex (ritek) 2 "worked" but yielded terrible results and the 3rdd failed. Now im geting the run around from them, as Im trying to get a replacement.
A 50 pack of 8x (ritek too) I got thought works great.
It depends what drive and FW youre using as well that give you better or worsre burns, so to say that they are all bad is opinion not fact.COPIED OVER 600 DVDS SO FAR -
I bought a pack of DVD+R Memorex and a pack of DVD-R Memorex when I got my first dual format burner. It seems, for the most part, that the DVD-R Memorex are really crap. I know some people on this board swear by CMC media because they produce pretty little reports with low error rates, but have you seen these discs after a year? Half of mine don't even work!! However, I have used the DVD+R which were RicohJPN. Good stuff. Not one problem. Same media code, in fact, as the 200 Aritas I bought from Office Max over a year ago. All of them still play perfectly. Like an early poster said, you never know what you are going to get.
Princo, on the other handI've had quite a few 'go bad' within a year or so.
imo memorex is brand for people with very little info about dvd media its for the type of people who just want basic dvd media.
i use only riteks and fuji's or maxell..
lord smurf knows alot about media as he has probably used them all..with his huge collection of toons.. -
well i like the cmc dvd-r 8x, i forget the code offhand, but there 12x media
in one of my burners not that 1 minute matters, but they burn semi good with decent qulity burns even at 12x, but i from now on only buying verbatim and fuji MIJ stuff,
cause its about the same price, and if not worth the xtra 5 cents a disc
When I buy media I look for the best prices at http://www.salescircular.com/
[quote="steve2713"]
Originally Posted by crashnburn -
lol, watch one night when he falls asleep the mpaa will come raid his house
u can get most dvd movies for 10 bucks now a days, why take the risk -
I would just like to add my two cents. I've been reading these forum's for awhile and felt I should contribute.
I've had a Memorex DVD burner for a year now and it has been a workhorse! I've used Memorex, TDK, HP, and even Fry's GQ brand with no problems. I can honestly say that the coasters produced by this drive have been few and far between.
Take this for what it's worth. -
i used to by just strictly the memorex dvd +r's 4x (i dont know the media codes).. and mine worked good.. havent passed the1 year mark yet tho.
so i tried the printable dvd +r's...the first 3 i tried, failed so i returned them. again no media code for them either. -
Well, I sure wish I had read this thread before I bought a spindle of a hundred Memorex DVD+Rs. The first five disks from the spindle seemed to burn OK...until I checked them. The first sixty minutes or so comes out perfectly. But then, freezes, checkerboards, giant pixels--and, finally, ejection.
It's not my burner; I checked by trying another disk and there's no problem with it.
Thank God I still have the VIDEO_TS files on my hard disk.
Hopefully Fry's Electronics will take them back. They're pretty good about equipment, less good about what they call "consumables". -
before u hike down to the fry's, make sure u got the newist firmware, and if there cmc which sound like so, u may wanna try a differnt write strat
Memorex DVD-R
By ozab in forum MediaReplies: 9Last Post: 15th Oct 2009, 18:37 -
memorex mvdr2102
By holtz in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Apr 2009, 09:07 -
Problems with Memorex Media. Where to buy Taiyo Yuden?
By John Shumate in forum MediaReplies: 11Last Post: 19th Dec 2007, 13:38 -
Memorex DVD-DL "RITEK S04" PLEASE UPDATE the media section.
By Crazyj32 in forum MediaReplies: 12Last Post: 13th Nov 2007, 02:28 -
Memorex DVD+R DL 8X Media Not Being Read
By Surfmaster in forum MacReplies: 10Last Post: 12th Nov 2007, 12:59
