  1. I have an album on my pc which reads as one track only but obviously with about 20 odd songs on it. I would like to separate the track so I can flick from one song to another. Which tool would you recommend to carry out this job?
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    theres a few ways to do it
    if you were wanting to play it off your PC you could setup a cue file, and in the cue file you specify each track
    if you wanted to listen to a CD then i would burn it using nero and in nero you can split the album to separate tracks
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    mp3 cutter joiner can do the job.
  4. I looked at nero and all I could see is Audio Edit, is it that? If so, how do u use it. I never have & have no instructions and it seems really complicated
  5. Member Dr_Layne's Avatar
    Nov 2002
    I don't know if it's freeware still, but there is a program called CD Wave that can split tracks and save them as seperate tracks, or it can generate a cue sheet so you can burn the wav to a cdr as seperate tracks.
    http://www.milosoftware.com/cdwave/
  6. Member Safesurfer's Avatar
    Mar 2004
    Nero 6 Ultra Edition has an app called Nero Wave Editor. Under the Edit menu, there is an option to "Insert track split." You will also see an option to "Save tracks as Files." under the Edit menu as well.
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
