Does anyone know what format(s) does the split tool support ?
In the case at hand the input is a large (8 G) mpg file which I want to author as a set of two DVDs. I have used the split tool but to no avail: the output is always only one DVD folder.
I have tried with mpg inputs encoded with both with ffmpeg and mpeg2enc but with no success. The output is only one folder.
Ruben
Ruben Leon
Dept of Computer & Information Science
Strathclyde University
Scotland
The split tool never outputs a DVD folder. Make sure that to use the split tool, you click "Split" in the filters tab and not "Encode". However, splitting muxed mpg files does not give perfect results. You could try to demux then remux with "Author as DVD" disabled (enter target filesize in the video tab "MB" field).
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 15:03 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 21:45 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 16:37 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 10:21 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 14:45
