I was wondering if it is possible to use the digital out on my DVD player/HDTV to connect to a soundcard in my PC to get sound out of my 5.1 computer theater system? I have Logitech Z540 speakers (I think, or they might be Z640).
I am thinking about the 5500s, does anyone have any experience/input on using a PC-based theater system for home theater sound?
Thanks alot![]()
get sound blaster audigy 2z or z2 i ferget.. lol its the cheapest of the z2 (vice-versa) family i got one with my logitech z-5500 and they work very well.. ima newbie with soiund cards so i might be mistaken but s.b z2's work very well they're 100$ new iono bout used ..hope this help ya ^^
i see u got logitechs... but iono how big urs are but.. from the pics on the internt to seeing them packaged.. the z-550.. are frikn huge.. lol subwoofer..... crazyness...cant even put it half way until everyhting starts shaking.. its worth the moeny -
I know it can be done with a SoundBlaster Audigy 2ZS Platinum soundcard (which is what I have). All the "ports" on the card itelf are outputs (analog and digital). To send a digital signal to the soundcard you need to have the Platinum version of the card which has the front panel with all the inputs (which includes an optical input). Now, there is also a digital CD audio input on the card itself but you would have to run the wires into the case since they are located on the top of the card.Originally Posted by soloredd-Shimon
Thanks for the feedback, shimonmor. I guess I'll have to think about either going the soundcard route or buying a dedicated home theater system (the latter would probably be more functional in the long run).
No problem. This stuff is all pretty new to me. I've had the SoundBlaster card for a while but never really used it until I got the Logitech Z-5500 speakers a couple of weeks ago. And I've been blown away by them and am starting a DVD-Audio collection. DVD movies have also taken a turn for the better as far as audio is concerned with DD and DTS.Originally Posted by soloredd
A great resource (in case you don't know) for audio questions is the AVS Forum. I've learned a lot just from reading through the postings.-Shimon
Substitute a USB audio device for dead laptop soundcard? [SOLVED]
By usually_quiet in forum ComputerReplies: 14Last Post: 1st May 2011, 23:17 -
Capture video from DV-camera and audio from soundcard
By NiQ in forum Capturing and VCRReplies: 1Last Post: 25th Mar 2010, 11:57 -
Digital audio crossover for DVD playback?
By bibo01 in forum AudioReplies: 0Last Post: 25th Oct 2009, 10:47 -
How do I create a Digital Audio DVD?
By chrisf71 in forum AudioReplies: 10Last Post: 25th Jul 2009, 22:00 -
No audio when DVD Folder is played on Netgear Digital Entertainer.
By Back2Future in forum Authoring (DVD)Replies: 6Last Post: 23rd Nov 2007, 01:42
