i would like to know how to make a svcd with both dual languages and optional(removble) subtitles , using dvd2avi and TMPGEnc
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press
To make an SVCD w/ selectable subtitles you need I-author (this program is next to impossible to find). Even if you find it most DVD players don't support selectable subtitles on SVCDs
http://www.vcdhelp.com/svcdsubs.htm has the info
However, making multiple audio tracks is fairly easy.
1) Rip DVD
2) Use DVD2AVI to generate D2V (video) and wave files (one for each language you want). Remember that the 2nd audio track takes up bitrate, so I suggest that you encode both at 128kbit/s instead of the standard 224kbit/s.
Take a look under the "Tools" section to the left for the vcdhelp.com bitrate calculator, used advance mode and determine your bitrates.
3) Run TMPGenc. Load the SVCD template. Then load the unlock template (should be in ../templates/extra). Use the audio1.wav as input to generate AUDIO ONLY audio1.mp2 then make audio2.mp2 (if necessary click settings and lower bitrate)
Load the D2V video source, and encode VIDEO ONLY to M2V file. (if necessary click settings and lower bitrate, make sure resolution and aspect ratio are correct [unlock can muck this up])
4) Mux everything w/ bbMPEG encode: video.m2v + audio1.mp2 + audio2.mp2 -> xxx.mpg
You can switch audio tracks by hitting the audio button you your remote. -
would permanent subs be easier
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
SATA removable drive bays?
By beavereater in forum ComputerReplies: 0Last Post: 25th Apr 2012, 05:11 -
How to burn a mkv file to dvd with dual audio and subtitles with nero.
By drkcloud in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 04:48 -
Removable hard drive tray issues
By Krispy Kritter in forum ComputerReplies: 5Last Post: 17th Dec 2007, 10:39 -
Removable SATA guide required
By kurbads in forum Newbie / General discussionsReplies: 17Last Post: 3rd Aug 2007, 03:39
