I am having troubles with DVDCOPY3 I had purchased recently. When trying to create a DVD from two XviD files, the VOB of the second file is very large (>> 2G) and thus the DVD is not compatible (can be played in the computer, but not on stand alone player). Any remedy to that?
codudi,
if your file is > 2GB but < 4.7GB you should be able to fit it on a DVD5. How did you create your dvd with DVDCopy ? Did you create directly to DVD media or first on the hd and then burnt to DVD media ?
More details are required. -
I created the DVD into a folder, and then tried to burn with Nero. It generated an error message that one of the VOBs is larger than 2G and cannot be stored on ISO compatibile and suggested to use UFO. I think UFO is not compatibile with topset DVD player.
InterVideo Home Theater
By aadis in forum Capturing and VCRReplies: 8Last Post: 4th Feb 2011, 02:55 -
I am looking for nVidia, Sonic and Intervideo codec
By Sean_ve99 in forum DVB / IPTVReplies: 7Last Post: 4th Jun 2010, 03:48 -
Intervideo DVD Recorder in Vista?
By jubbely2 in forum Capturing and VCRReplies: 0Last Post: 13th Jun 2008, 12:40 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
intervideo dvd
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 10:37
