I use TMPGEnc DVD Author 1.6 to do my DVD. I keep getting these errors.
*The video resolution AAAxBBB cannot be used for a standard DVD.
For a standard DVD you can only use the following resolutions:
352x240 352x480 704x480 720x480 pixels (NTSC format only)
352x288 352x576 704x576 720x576 pixels (PAL format only)
*The video framerate xxxxxx fps cannot be used with the resolution xxxxxx.
This framerate can only be used with the following resolutions:
*The video GOP is too long.
For a standard DVD it is necessary that the GOP fulfill the following condition:
Max 36 fields (18 frames) (NTSC format only)
Max 30 fields (15 frames) (PAL format only)
HELP!
What is the exact format/framerate/framsize of the file you are trying to use?
format: avi
framrate: 23.976
framsize: 640x256 (2.50:1) [=5:2](dont know if that it)
in TMPGEnc DVD Author 1.6 I used NTFC
format: MPEG-2
framrate: 29.97
framsize: 720x480
hope that helps -
You have to encode the files to MPEG-2 first, TDA will not accept AVI files. I'd recommend you get TMPGENC Plus, and encode your AVI to 720x480 NTSC, using a 3:2 pulldown to keep the 23.976 framerate.
fixed - i kant tiep
You are in breach of the forum rules and are being banned. Do not post false information.
/ Moderator John Q. Publik -
Originally Posted by Forum Troll
/Mats
Cutterman Errors
By TwoMutts in forum EditingReplies: 2Last Post: 9th Apr 2009, 15:27 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Disc C2 Errors
By kidcash in forum MediaReplies: 1Last Post: 5th Jul 2008, 11:56 -
How to scan for any errors?
By Kwan in forum Newbie / General discussionsReplies: 6Last Post: 1st Oct 2007, 06:59 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
