I have started to back up my frist season of the Sopranos. I noticed that fitting 4 episodes on one dvd-r is not a good idea (very low quality). So I ripped the four individual episodes... using the Title chapter extraction mode in MTR.. then joing the 3 video_ts files and popcorn to burn and i get this message: " This is not a valid VIDEO_TS folder. it cannot be selected". so then I tried to burn two of the episodes with toast, every thing was going fine when half way thru the the process I got an error message about some missing files.
Am I doing the right thing or is there another way to do this. Sorry if this was posted somewhere else but I could not find it. thank you
you just cant join data this way in the VIDEO_TS....
you need to demux these files and use a authoring tool to reconstruct a VALID video_ts folder prior to burning.
GB -
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
If you want to use Popcorn, the best thing to do is take the entire VIDEO_TS disc from the original disc and use the full disc copy option. Popcorn doesn't allow you to select individual titles from episodic discs individually.
Cooling Solutions - *Solved & updated* Problems w/overheating & idle temps
By Noahtuck in forum ComputerReplies: 21Last Post: 28th Jul 2010, 21:30 -
C-200 Popcorn Hour chapter skip & bBu-Ray iso
By neworldman in forum Media Center PC / MediaCentersReplies: 1Last Post: 12th Jul 2010, 21:20 -
Student needs help adding subtitles to Sopranos without converting
By Dains11 in forum SubtitleReplies: 12Last Post: 28th Aug 2009, 09:15 -
Do you prefer fresh popped popcorn or day old popcorn?
By yoda313 in forum PollsReplies: 20Last Post: 14th Jul 2009, 22:16
