i have a divx file that wont work on a friend's mac. i would like to know whats the easiest way to convert this file to a format that his quicktime will definitely be able to recognize.
thanks
ok, i have concluded that its a problem with the audio of why it wont work by trying a sample encode with no sound.
does anyone know of a fail proof format to convert the audio to after i strip the audio out with virtualdub-mp3 fix? -for some reason, tmpg complains about the direct .wav file from virtual dub saying its "illegal" -
Did you rip the wav using "Full Processing" in virtualdub?
Use tmpgenc to encode the .wav to .mp2 then mux with the m2v video, or just use the .wav as the source audio during encode.
Goldwave will let you resample the original to 48khz, and THEN save as .wavCheers, Jim
My DVDLab Guides
serious codec issues mac?
By aceswild in forum MacReplies: 10Last Post: 20th Nov 2009, 13:45 -
serious quicktime issue, basic MOV codec corrupt? mac
By aceswild in forum Video ConversionReplies: 1Last Post: 18th Nov 2009, 15:46 -
K-Lite Codec for mac
By pixel zombie in forum MacReplies: 3Last Post: 9th Jun 2009, 03:25 -
This is a tough one! Codec issues - my devices aren't playing friendly
By Kevo123 in forum DVD RippingReplies: 1Last Post: 25th Mar 2009, 15:53 -
How to get avi codec for mac????
By balonglong78 in forum EditingReplies: 14Last Post: 9th Feb 2009, 19:13
