Just noticed the quality of a program "Surviv0r" (latest one). The whole show was blocky when there was movement on screen.
The Commercials were fine.
Just wondering if it is the way the program was recorded (I'm in Oz on Pal)
Maybe an NTSC program modified to PAL for the rest of the World.
352 res changed to 720 for rest of the world.
Or is it the Station Channel saving bandwith via the satellite and transmitting?
Or should I mix more softdrink with my scotch.
I'd say the opposite.Originally Posted by garry
In fact ... might as well just drink the scotch straight up.
That way if your TV program looks shitty ... you won't be able to tell!
Most low badget DVB channels look like shit when you watching them. Few of them are 352 x 288 in Europe! Yeap, that low ... (with ~1000kb/s!!! Less than VCD that's it!).
Just for the info: With msu_deblocking filter, you can filter some blocks out on those cases. I do it all the time (msu_deblocking for DVB transmissions is like rm_PAL for VHS tapes...)La Linea by Osvaldo Cavandoli
Channel 9 probobly are getting a satelite feed, rather than tapes, last season looked preaty good in comparison.
http://www.dtvforum.info/index.php?showtopic=15059
HTPC Digital Signal Reception
By lacywest in forum Media Center PC / MediaCentersReplies: 5Last Post: 12th Dec 2011, 09:42 -
HDTV reception works on some TV's, but others.....
By riverpine in forum DVB / IPTVReplies: 20Last Post: 22nd Sep 2009, 13:46 -
How is your DTV reception after the transition?
By freebird73717 in forum Newbie / General discussionsReplies: 114Last Post: 20th Jun 2009, 21:31 -
Questions about reception with new converter box
By johnsees in forum DVB / IPTVReplies: 24Last Post: 31st Aug 2008, 11:28 -
Wavy lines on tv reception (tapes too!)
By JudgeGarth in forum DVB / IPTVReplies: 4Last Post: 27th Feb 2008, 11:56
