hi folks.
i have a serious problem.
im from germany and i'd like to digitalize a NTSC movie, in order to make a VCD out of it! therefore i have to capture it to hdd.
my equipment is a winTV PVR capture-card and a "ntsc-playback" videorecorder. i used to capture my stuff with virtual dub.
i thought, this should be no bigger problem, because i can watch this ntsc-movie with this recorder on my normal tv.
but, when im trying to capture it with my pc (winME) all screws up and i only can capture a black&white, tilting movie.
what do i wrong? can anyone help me out of this misery?
remember, im from germany, we normaly have PAL.
great thanks,
pascl
hi pascal,
the wintv pci records only standard NTSC at 4.429Mhz
so you need a videorecorder able to playback
real NTSC. NTSC playback on PAL-Tv gives you a NTSC
picture (525lines/60Hz) with Colorinformation in PAL so the
wintv pci records only the picture without color.
cya,
rufus -
hi, thanks 4 your answer, but where in hell can i get an REAL-ntsc playback recorder else where as if in america?
so ... is there no other alternative way to do this? can another capturing card handle this problem or do all the german card do hav this problem?
tnx, pascl
p.s. are there any hardware differences between the american and the german capture cards?? which?
Trying to Change Language in a newly converted NTSC movie
By thedon01 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2011, 23:16 -
NTSC -> PAL same movie length?
By busta3396 in forum MacReplies: 5Last Post: 6th Mar 2010, 07:30 -
Do I use NTSC or NTSC-movie in DVD Flick?
By Belfour in forum Authoring (DVD)Replies: 1Last Post: 15th Sep 2008, 11:11 -
Help with deinterlacing this NTSC 29.97 movie
By Talayero in forum Video ConversionReplies: 13Last Post: 19th Apr 2008, 18:58 -
Is “Movie Clone 4 Gold” capable of converting PAL into NTSC?
By coody in forum DVD RippingReplies: 3Last Post: 5th Dec 2007, 17:39
