Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
    Mar 2012
    Russian Federation
    Ohh, it would be a good idea to see picture with and without this expensive device.
    I found, on this forum, pictures showing the job of TBC 1000. And it really removes twisting (top, bottom) of a tape. Also, it improves overall picture quality. So, I decided to buy it anyway.
    Now I'm thinking if PA-100 is so necessary.
  2. Banned
    New York, US
    If you already have enough to do what you want, it shouldn't be necessary. The PA-100 doesn't sharpen. It controls white levels, black levels, and color.
    Mar 2012
    Russian Federation
    I don't know if it is enough - because I didn't see PA-100 work.
    Also, I don't have anything at the moment, I just start learning and buying.
  4. Banned
    New York, US
    Detailers don't correct those levels. But you might not need that. I don't use mine all the time. Often, it isn't needed. No hurry. You asked about it, and anyone who knows the PA-100 would highly recommended it, if the need arises. IMHO in that price range or lower, and compared to high-end/low-end, there's no competition until you get into some really pricey studio gear. Many pros use it. For pro use, it's cheap.
