I am trying to take some things outta start up on a computer running windows 2000 pro. Where is the msconfig or where do i have to go to take things outta start up
You can get a copy of msconfig for Win 2000 on this site:
http://www.kulsar.co.uk/downloads.php
msconfig is in the folder "Windows Utilities"
Hope that this is helpful.Cole -
Plus, when you use MSCONFIG in Win2000 it will display some error messages that it cannot find autoexec.bat, etc. These are normal as Win2000 does not use these files (they are legacy config files from previous versions of Windows). Just click OK on each that comes up, and eventually the main program will open.
You are in breach of the forum rules and are being banned. Do not post false information.
/ Moderator John Q. Publik
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31 -
Core2 Quad with Windows 2000?
By SatStorm in forum ComputerReplies: 18Last Post: 21st Aug 2007, 18:29 -
Windows 2000 Hotfix
By MarioB in forum ComputerReplies: 13Last Post: 18th Jun 2007, 13:39 -
Windows 2000 options, if any.
By AlecWest in forum Capturing and VCRReplies: 6Last Post: 18th Jun 2007, 00:22 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
