  1. On my win98se Celeron 700 system, I just installed svcd2dvdmpeg v 1.1 and it works properly.
    SVCD2DVD V2 RC5 demo will not open properly without errors, and is not functional. Presently using 1.1 with DVD Lab Pro, which works well, but is very very slow. I would really love to have this working. The following ouputs were generated by the errors:
    SVCD2DVD Run Error:
    “An unhandled exception has occurred in your application. If you click continue, the application will ignore this error and attempt to continue. If you click quit, the application will be shut down immedietely.
    Warning: A StringBuilder buffer has been overflowed by unmanaged code. The process may become unstable. Insufficient capacity allocated to the StringBuilder before marshaling it.”
    Here are the details of the error message:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IndexOutOfRangeException: Warning: A StringBuilder buffer has been overflowed by unmanaged code. The process may become unstable. Insufficient capacity allocated to the StringBuilder before marshaling it.
    at x3284ccece41ee22b.xe679539bc4bbd8b5.StrFormatByteS izeW(Int64 x364dcb7d747451c5, StringBuilder x66c92f860448b47e, Int64 xf3a99d163b980af9)
    at x3284ccece41ee22b.xb6dca8349e33d934.x291868888b502 1b9(Int32 x0ceec69a97f73617)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x21f497a09c280 fd5()
    at x3284ccece41ee22b.x210ff09a2516b1a7.xc456b78441ff1 c49()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.0.1867.34019
    Win32 Version: 2.0.1867.34019
    CodeBase: file:///C:/PROGRAM%20FILES/BADGERSOFT/SVCD2DVD%202%20BETA%20DEMO/SVCD2DVD.EXE
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    DevComponents.DotNetBar
    Assembly Version: 4.7.0.0
    Win32 Version: 4.7.0.0
    CodeBase: file:///C:/PROGRAM%20FILES/BADGERSOFT/SVCD2DVD%202%20BETA%20DEMO/DevComponents.DotNetBar.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.QuartzTypeLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/PROGRAM%20FILES/BADGERSOFT/SVCD2DVD%202%20BETA%20DEMO/Interop.QuartzTypeLib.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    SVCD2DVDLib
    Assembly Version: 1.0.1867.22426
    Win32 Version:
    CodeBase: file:///C:/PROGRAM%20FILES/BADGERSOFT/SVCD2DVD%202%20BETA%20DEMO/SVCD2DVDLib.DLL
    Microsoft.VisualC
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.3052.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Please drop me an email as i have a build which resolves this.
