I'm trying to do transitions between 2 movies in DVD-LAB pro. i have 20 different clips from different times and locations, i would like to have transition effect after each clip, in this case each clips is a chapter for my main movie. any help is very much appreciated.
thanks in advance!
Create a transition between menus.
Link the transition between your movies manually.
You can then rebuild the menu links to avoid the transition.Cheers, Jim
My DVDLab Guides
FREE transition plugins for Premiere pro cs3
By mudh in forum EditingReplies: 0Last Post: 14th Oct 2011, 18:00 -
How to control transition length in Vegas Pro 10?
By gutterboy in forum EditingReplies: 4Last Post: 14th Oct 2011, 16:12 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 1st Jan 2010, 00:01 -
Problem with adding transition effects to HDV footage in Vegas 9 Pro
By btodorov in forum EditingReplies: 4Last Post: 24th Aug 2009, 15:46 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 05:42
