anyone know how i can fix this, when i open a new project in ulead, after chosing the settings and clicking ok, the box comes up that says "BtVid Failure loading VxD driver".. any solutions?
I have seen this error before in ULEAD (VideoStudio ?) but I don't use it enough anymore to remember the cause. I would try one of two things:
If you are using one of their standard templates to start your project, then use an existing file as a template instead. Otherwise, if you are using an existing file already, then try a standard template which is similar to the file you want to edit.
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 03:51 -
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 19:41 -
dv/ulead capture, aspect ratio problem
By Statick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th Jan 2008, 15:46 -
Ulead VS10 sound problem
By theguy1991 in forum EditingReplies: 1Last Post: 3rd Dec 2007, 19:06 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 10:23
