I have some ISOs (maybe 1/5 of a DVD), I want to edit them (cut) and re-encode them so I can put them on DVD with some mpegs I have. First, I tried to extract the ISOs (files are in WinRAR archive) and it fails (tells me I need a previous volume to start to extract the file and also that the files are corrupt). I tried using UltraISO and nothing happened when I tried to extract the ISO. (I don't know exactly what WinRAR is, it just appeared like a zip file and installed on my computer one day when I downloaded from the net). Any suggestions would be appreciated.
Mount the iso in Daemon tools. Copy it to your hard drive.
Cheers, Jim
My DVDLab Guides -
I've tried unpacking ISOs with winrar and it doesn't work for me either. Do as "reboot" stated. This is what I did and no problems so far.
I managed to get it (maybe 200 MB) into DVD2AVI and created D2V and WAV files. Then I imported them into TMPGEnc and it stopped while it was reading the field order and said "ran out of memory". I have sufficient RAM available I've never run across this, over the past two weeks I've loaded at least 6-8 large files into TMPGEnc every day and never had this occur.
I can't get Daemon Tools to work. I install, reboot, start it and nothing happens. Tried this several times.
Edit ISO files
By Leo48 in forum Newbie / General discussionsReplies: 8Last Post: 29th Nov 2018, 04:15 -
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35 -
How to fix/edit a damaged video iso?
By hibbs in forum Newbie / General discussionsReplies: 8Last Post: 20th Jul 2010, 17:24 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01
