Hi every one, i burn CDs a lot and what i dont like is when the volume between tracks vary. so is there any program that can equalize volume throughout tracks, preferably freeware? thanks, happy posting.
Results 1 to 9 of 9
Wow! You got shocks, pegs... LUCKY!
moved you to the Audio forum
/moderator bugsterThere are 10 kinds of people in this world. Those that understand binary... -
Cheers, Jim
My DVDLab Guides -
Which burning application are you using? If it's Nero then it will do it for you. Once you've added all your tracks to the complilation, select them all, right click and select properties. You will see an option to add a "Normalise Filter". This will standardise volume across the tracks.
If your burning software doesn't support this, you have other options. If you are using mp3 as your source try mp3gain here:
http://mp3gain.sourceforge.net/download.php
If you are using ripped CD tracks (.wav) then you could try this app (only one file at a time though)
http://www.bheller.com/file/NormalizeGUI.zip
You can pick up a Nero copy so cheap though, and check your burning app if it sisn't Nero, see if there's a Normalise option hidden anywhere. -
NERO will volume equalize all your tracks.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
This is only true when creting an audio CD. I personally wish it could do this when burning an MP3 cd as well. It is a pain listening to MP3s in my truck and the volume is up and down hehe
iTunes will do it. It's free. It will do audio CD or mp3.
Jesus Saves!
Weight rebounds, HE SCORES!!! -
This is only true when creting an audio CD. I personally wish it could do this when burning an MP3 cd as well. It is a pain listening to MP3s in my truck and the volume is up and down heheNo DVD can withstand the power of DVDShrink along with AnyDVD!
program
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2011, 05:23 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
which program?
By MONSTERTITO in forum Authoring (DVD)Replies: 1Last Post: 1st Oct 2008, 12:30 -
Does anyone know a program that does this?
By dcsos in forum AudioReplies: 6Last Post: 10th Jul 2007, 06:05
