    Dec 2003
    Earth
    been using TMPGEnc and Super Dvd Creator as backup if TMPGEnc can't read the avi.
    TMPGEnc encode avi 20% faster than Super Dvd Creator and apart from those avi + ogg audio avi movies that it can't recongize. TMPGEnc can read all other types of avi combinations.
    any other good avi decoders to recommend?
    Fact is stranger than Fiction
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    VirtualDub -> frameserve to encoder. Do you have the ogg codec installed? On such occations where audio is a problem, you'd better extract audio, decode to wav, then use the wav as audio source for TMPGEnc.
    /Mats
    Jun 2004
    USA
    Give CCE Basic a try, it is around $58.00. It is fast and does a good job.
    bits
