hi everyone, i just wanted to ask a very basic question, if information about my computer its required, it can be found in my profile. thanks.
Results 1 to 11 of 11
Wow! You got shocks, pegs... LUCKY!
The video card (no idea) is where your problem lies. You can get a video card with an RCA out jack. Be warned though, stuff that looks great on a computer can looks like ass on a TV...
haha.. i love your wording. thanks for the great reply, i love honest answers. o my video card is NVIDIA GeForce Ti 4200 (listed just recently in my profile). thanks again.
Wow! You got shocks, pegs... LUCKY! -
Look for a video card that has an out to tv option.
It will either be S-video or RCA -
Usually, most video cards have S-video on them. My old Geforce MX440 had a S-video connector so the Geforce Ti 4200 will certainly have it too.
You can also use a scan converter.
I have a few Hyperconverters that I bought on ebay.
The text usually stinks when viewed on a TV.
They are cheap and you won't have to install a new video card. -
o ok, so basically my comp IS compatible, but exactly what tools (cables) do i need to hook up my TV. i see an S-VIDEO thingy on my comp but my TV only has the 3-analog (red, white, yellow) connection slots, and the regular cable wire. im pretty sure there is no way to get in through the cable wire, so how do i connect it through the 3-analog slots?
If you only have s-video on the PC you can buy an adapterOriginally Posted by skip2mylou
for S-VIDEO------>RCA and connect to the yellow on the TV.
http://www.amazon.com/exec/obidos/tg/detail/-/B00007KJUK/104-7822554-0326359?v=glance
http://www.cablesnmor.com/s-video-rca-adapter.html
For the audio use a cable like these...
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=12-2057
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=240-135
Plug the mini into the LINE OUT on your sound card.
Plug the RCAs into the RED and WHITE on the TV.
You can also buy pre-made AV cables. -
ok, thanks. believe it or not i might have these gizmos lying around (i once experimented a way of capturing video from my VCR, not to mention it was totally ridiculous, but i think i bought these thingys) i know i have the audio thing majiggy, but i dont think i have the S-VIDEO doo hicky. however i might have something that might work. o well, thanks again, i cant tell u how much i appreciate this.
on another note, is there a way to connect my standalone VCR to my comp and record what is on my comp screen??Wow! You got shocks, pegs... LUCKY! -
S-VIDEO out from the PC to VIDEO INPUT on the VCR mightOriginally Posted by skip2mylou
work but the text might look terrible.
But.....maybe the VCR can't be set up as a 'TV OUT' device
in your video card settings.
A thing majiggy and a doo hicky???
hey thanks shadow57, much appreciated. o BTW, it must be the NEWBIE-itis.
need help, i want to hook my laptop to the tv
By sonicslayer in forum Newbie / General discussionsReplies: 15Last Post: 10th Jul 2011, 16:23 -
pc to tv hook up need opinions
By xsfcloud in forum ComputerReplies: 6Last Post: 4th Aug 2009, 13:51 -
I want to hook up my printer through my router
By lordhutt in forum ComputerReplies: 7Last Post: 8th Oct 2008, 21:28 -
Hook Up Problems!!
By rebekahneedshelp in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Jun 2008, 23:35 -
Help With PC2Telly Hook up?
By Ghettorapboy7 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jul 2007, 14:55
