Is there a prog. to Identify specs on a previosly recorded VCD,Svcd,Xvcd .such as whether it was recorded in vbr or cbr, bite rate , pal or ntsc ?
thanks for any help................Bizarro
Get vcd easy, check the advanced settings and under the tool section there is an app that will analyze your mpeg.
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 19th May 2010, 00:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 04:19 -
Easiest and fastest ripping prog?
By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 18:57 -
Subtitle workshop function help (or other prog)
By Tobberian in forum SubtitleReplies: 4Last Post: 22nd Jun 2008, 11:50 -
What prog. encodes several videos without burning?
By Shapeup1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 19:16
