I normally don't have any problems, using "DVD Shrink 3.2", but after I made a bck up copy of a DVd, I wanted to make a back up, for the back up. It wouldn't do it. So I was able to save the files from the dvd, to the hard drive, that went well, but when I opened these files, and tried to burn them, I got this error message from DVD Shrink:
"DVD Shrink encounted an error and can not continue There is Not Enough Space On Your Target Drive".
My target drive, is my Burner, which is a "LiteOn DVDRw SOHW 1633s"
Can someone, please tell me, what I am doing wrong, and how to solve this problem? Thanks In Advance...
Was it in the process of re-shrinking when you got the error message, or had it actually started burning? If it was re-shrinking, you probably ran out of scratch space on your hard drive.
is the backup a single layer ( DVD5 ) if it is you dont need to use dvdshrink
just dvddecrypter read ISO then write -
Standard disc copy makes a wonderful backup of a backup
Sabrowww.sabronet.com - It's all you need...to know -
Just a thought ,,,, Why don't you just repeat the process using the original!!!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Me thinks maybe he no longer has the original! But wait! that would mean...... surely not........... let me think a backup of a backup and no original................. No, I am lost!
Just re-copy the original....... if you can... of course you can... -
All joking aside, you can simply and literally drag both VIDEO_TS and AUDIO_TS onto you HD and re bun it. It really does not need to be re- ripped. The backup is not protected, right!
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 08:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 21:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 12:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 09:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 11:21
