it's come that time that i need to add a hdd. the space i have isnt enough anymore. the problem is that i want to go sata(seagate 200gb) but my mobo doesnt have sata onboard![]()
so i first started looking at sata controller cards. seems like the simplest solution right? well i found this one. looks pretty good. not bad for the price. well a few scrolls down for $5 more they have this listed...
now i know its a refurb but still a solid mobo runnin kt880 for $5 more? prices have just gotten stupid. right now im runnin a shuttle nforce 2 which is...eh...at best.
so i guess it's not really a dilemmaunless somebody can give me a really good reason not to go for the mobo
Results 1 to 10 of 10
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
Main reason I can think of not to get the MB is the possibility of having to reinstall the OS or running into other OS-related probs associated with changing MB's. Doesn't seem worth it to me unless you're upgrading CPU + RAM at the same time.
xp does a pretty good job of recognizing everything. i might just to a fresh OS install. cpu and ram are up to date so no reason to buy new. i dunno though. like u said it's a pain in the assOriginally Posted by Zisguy1
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Install the new hardware. Run XP setup as a new install. Right after you press F8 to agree to the TOS, you'll get prompted to "Repair a current installation". Hit "R", and let it repair.
Done.
We do this 4 or 5 times a day at work, on customer's computers, with no troubles.Cheers, Jim
My DVDLab Guides -
cool thanks. makes sense to me. awhile back i put it so that repair proggy runs on every boot. it's on the hdd. so should be no trouble.Originally Posted by rebootPhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
The first thing you do after running the repair, is to install all the drivers for the new mobo from the CD that came with it.
We're ripping out Asus P3B-F's, MSI/Duron combo's, and a ton of junk, replacing with a lot of Kt4 and Kt8's, and this works every time.
A little time consuming, but we haven't had a system OS failure yet.Cheers, Jim
My DVDLab Guides -
is it not better to uninstall everything before putting the new mobo in?
NEW DILEMMA...
ok so i was originally looking at the sata 200gb seagate
http://www.newegg.com/app/ViewProductDesc.asp?description=22-148-033&depa=1
BUT i kept looking through the refurb section of newegg hehe and found
http://www.newegg.com/app/ViewProductDesc.asp?description=22-152-015R&type=Refurbished
so i can get 2 of the 160gb samsungs and run a raid setup for the same price as 1 200gb seagate..
You could uninstall it all, but we've found (through hundreds of these upgrades) that it's not necessary.
XP is very forgiving of this, and the only hassle encountered is the re-authorization, or whatever MS calls it, because of a major hardware change.
If you're going to run RAID, what type?
I find that redundant IDE raid setups are a waste of time and space. Better to use the drives independently.Cheers, Jim
My DVDLab Guides -
cool. thanks for the info.Originally Posted by reboot
they're sata drive's. i'd run a raid 0PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
nevermind. newegg took off the refurbed samsungs
im a day too late. so i guess im getting the seagate
DVD mastering dilemma..
By sdsumike619 in forum Authoring (DVD)Replies: 7Last Post: 28th Sep 2011, 17:08 -
f4v dilemma
By tarsierspectral in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 09:15 -
TV/Monitor Dilemma
By meneedit in forum Newbie / General discussionsReplies: 13Last Post: 19th Dec 2010, 14:54 -
Mp3 player dilemma
By alintatoc in forum Off topicReplies: 1Last Post: 10th Dec 2009, 17:11 -
Dilemma of vertical recording
By Air7LSI in forum Authoring (DVD)Replies: 9Last Post: 24th Dec 2008, 04:47
