Can I just copy a +R DVD to -R ?.I copied a +R DVD to a -R DVD.The burn completed,but Nero said that it failed.I played the DVD and seemed to work but haven't viewed it all for errors.Do I need to perform a certain method or can you do just a sraight copy?.Thanks
Results 1 to 10 of 10
Yes.Originally Posted by Ripper64Want my help? Ask here! (not via PM!)
DVD+R to DVD-R should be no problems.
DVD-R can hold i little bit more data than a DVD+R (I think the difference is 6 MB or something like that). So the other way, DVD-R to DVD+R may be a problem if the DVD-R disc was filled to the very limit. -
Where do you find this information?Originally Posted by ronnylov
WHy not simply re-burn the original file to DVD-R
No DVD can withstand the power of DVDShrink along with AnyDVD! -
It's true, but it's just a couple MB (count on your fingers).Originally Posted by MpegEncoderWant my help? Ask here! (not via PM!)
I could re-burn the original.I just thought it be quicker to just do a straight copy than go through the whole routine.Not that its a big deal.Anyways,thanks for the replys.
I wasn't asking for verification. I would like to know where people get this kind of information. Thanks anyway.Originally Posted by lordsmurf
I have read it somewhere, I think it was on a German forum, I'm sorry that I can't give you a more exact answer where I found that info. I have written it down, let's see.
Here is what I have read about sizes:
All DVD+R/+RW: 4 700 372 992 Bytes
For DVD-R/-RW there are two sizes
- 4 706 074 624 Bytes and
- 4 707 319 808 Bytes
which can be both on -R och -RW.
But normally I count with 4 700 000 000 bytes as max on single layer DVD, it is easier to remember.
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 13:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
