  1. Hello,
    I am using DVD Lab Pro and use Switched Menus, are there any other program that can be used to make a switched menu?
    Also I have audio problems, I compile and burn and the audio is crackling a little.
    Please Help!
  2. Member pchan's Avatar
    Mar 2003
    Singapore
    You can use TMPGenc to demux and encode the audio to DVD compliance for DVDLab Pro.
  3. Clean up your audio in something like Goldwave, after extracting it from the source.
    Transcode it to AC3 in ffmpeggui, then use the AC3 as the audio in DVDLab.
    There are other apps than make switched menus, but none as easy as DLP.
    Cheers, Jim
    My DVDLab Guides
  4. Member GeorgeW's Avatar
    Feb 2005
    Any authoring package that supports a button "auto-activate" function can do switched menus. It might take a little more setup time because DLP uses a script to automate the menu setup.
    This DVD Workshop 2.x tutorial shows you how to set it up manually
    Rollover Over Effect
    George
