hello helpful people--i'm having a very irritating problem i need help with. i just installed a LITEON 16X DVD+-R/+-RW drive. it plays original dvd's just fine and it can copy them just fine using dvd x-copy platinum-however i cannot play back the copies on the same drive that burned them. i have tried burning them onto dvd-r and dvd+r discs and the problem still persists. the copies i have made do play on a set-top dvd player though so i know they copied ok. when i insert a copied disc it doesnt even recognize that a disk is inserted(this includes powerdvd, easydvd, and windows explorer). i know for sure that some discs i have are encoded using mpeg2 and i also know that i have that codec. i have played these discs before, but since i've played them i installed the new drive and ALSO upgraded from windows 98SE to XP pro. if anyone has any helpful suggestions it would be much appreciated!!
P3 ~ 807/mgh, 640mb ram, 60G hd space
I suggest you get rid of DVDXCopy and go to DVDShrink or DVD Decrypter. DVDXCopy is a commercial virus, IMO
I agree with Cap DVD Shrink or DVD Decrypter are much better solutions, they give you a wide range of options for backing up your dvds, even reauthoring. All free.Originally Posted by Capmaster
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 22:43 -
DVD's not playing properly after being burned
By Digger777 in forum Video ConversionReplies: 5Last Post: 26th Sep 2008, 00:52 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 17:51 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 08:46
