I have recently backed up some disksand they worked fine. Now I want to make a copy of the backup but I keep getting a CRC error - Can anyone help ? I have a NEC ND3500 Drive using Windows XP SP2 and normally use DVDShrink for my films
Any help would be gratefully received
Just try making a straight copy. All copy protection should be removed on the backup, so there should be no problems.
TANSTAAFL -
many posts on crc errors, try a search for them
crc is a probably a read error
try cleaning the disc
try using a different dvd-rom drive
try using a dvd burner to read it
try different ripping software, dvddecrypter, dvdshrink, vobblanker, isobuster, smartripper
theres even a toothpaste theory
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 09:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 01:50 -
dvd backup problems
By RemainsHuman01 in forum DVD RippingReplies: 1Last Post: 20th Aug 2008, 01:15 -
Help with DVD Backup
By zeroplace in forum DVD RippingReplies: 3Last Post: 23rd Jun 2008, 10:48 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 09:38
