I've converted my AVI to MPG and am ready to burn it as a VCD but it's too big. So I followed the instructs to split it using TMPGEnc which worked EXCEPT now when I try to burn the two halves as a VCD, NERO tells me that the .mpg file is invalid ...
it say a bunch of things but I think the key phrase is:
stream encoding which is invalid for a VCD
When I try to encode the entire .mpg file as a VCD it would work fine (I don't get the error MSG)if I could find a 1.5g CD![]()
Make sure you choose mpeg-1 vcd instead of the default auto
before you cut the mpeg. Otherwise it will give you non compliant mpeg. -
Yahhooo ...it worked thanks! I owe you a beer or whatever you drink. I've been stumped by that one for days .. ah, guess I didn't look close enough at that setting. Thanks again!!
You are welcome!
Then buy me the pepsi or coca cola X'mas edition! Thank you.
Thanks for the tip!!!!! I think I owe u about a six pack of Pepsi.... cuz I have been struggling with that for about a week... it was just one of those stupid things that I kept overlooking.... Thanks again
WVC1 file format to avi/mpg/dvd
By TunkaFrankie in forum Video ConversionReplies: 7Last Post: 24th Nov 2011, 06:51 -
Invalid file format
By DeepthiFdo in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jun 2011, 07:33 -
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
from ATI File Player to .mpg (or any format that fits WMM)
By croarta in forum Video ConversionReplies: 2Last Post: 22nd Dec 2010, 10:10 -
join 2 AVIs w/ VirtualDub, Truncated or invalid decompressed audio format
By Madgelina in forum EditingReplies: 3Last Post: 6th Mar 2008, 13:25
