how to enable MainConceptEncoder support rm,rmvb?
I have installed the k-lite maga codecs, but still can't work. any1 help?
Mainconcept does not support importing .rm or .rmvb to encode.
Convert them to .avi first if you need to, or use a different program to encode to mpeg.Cheers, Jim
My DVDLab Guides -
maybe if you install http://www.inmatrix.com/zplayer/formats/realmedia.shtml
i am pretty sure no mater what - they are not supported ..
but try anyway ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Unless Mainconcept made a recent deal with RealMedia, BJ_M is correct.
Cheers, Jim
My DVDLab Guides
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 09:53 -
Any reason why most dvd player only support xvid, divx and not rmvb and mkv
By c1steady in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2009, 19:14 -
How To Enable PC To Read DVD-R
By Jjay in forum Authoring (DVD)Replies: 10Last Post: 5th Jan 2009, 16:47 -
Enable Cookie Failed
By evol ecallaw in forum ComputerReplies: 14Last Post: 4th Jul 2008, 21:28 -
dvd players that support rmvb??
By lilxtwinkies in forum DVD & Blu-ray PlayersReplies: 4Last Post: 25th Sep 2007, 23:03
