Ok, thanks for your patience and clarity!
Yes that is what seems to be the problem here; a 23 something fps file converted to a 25 fps file.
I have downloaded avifrate and changed the fps setting to 25, then extracted the audio as wav by 'full processing'.
I'll start the framserver later when I am not using my machine.
Thanks again
Results 31 to 37 of 37
Bob Heselwood
Sorry for the dumb question, but how do I run the wav file thru besweetgui?
ThanksBob Heselwood -
Ok, just looking at the site now, and in virtualdub, where you say:
choose video direct stream and frame rate and change to 23.976 (pal to ntsc) or 25.000(ntsc to pal)
err whereabaouts in VD do I find that? I have looked all over but cannot see it.
I am using VD 1.5.2 and it is an avi file I have loaded.
Ok thanks for that reboot, I did find it eventually. doh!
johnso, I am having trouble now with the audio being out of sync with the video on the new avi I made.
Do I copy as direct stream or full processing mode, and then what can I do about the audio? It is behind the video. There is a kind of narration at the beginning of the video and it seems in tune so to speak, but the when the characters start to speak the sound is about 5/6 seconds behind.
ThanksBob Heselwood
How is a Smaller File a Better One?
By happydog500 in forum Capturing and VCRReplies: 4Last Post: 23rd May 2011, 20:50 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
Conversion of MPEG2 files to smaller size
By tonyaldr in forum Video ConversionReplies: 13Last Post: 2nd Aug 2008, 21:43 -
rotated video and conversion for smaller file
By rtdavide in forum Newbie / General discussionsReplies: 15Last Post: 19th Oct 2007, 08:25 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 22:57
