Hope someone can help me out on this one.
I´m trying with virtualdub to reencode a xvid file with Global Motion Compensation feature to a regular xvid.
Just read some post here in the videohelp forum and decided to use xvid codec with single pass, profile level AS @ L5 and used the bitrate calculator on the xvid codec to set my target bitrate.
I need the reencoded file to fit on a CD (700MB) so the target size on the calculator was set to: 716800.
Now my final file size is never around 700MB.
How can I get the correct file size for my reencoded video?
I also have a second question, should I chance something in the zone options or just the leave on the default options?
Anyway... what are the zone options for??? Can I just delete them?
Thanks for your atention in avance!
are you using direct stream copy for the audio?
how big is the file? smaller bigger? different all the time? -
Sorry Baldrick... I forgot to tell some other settings... and file size!
Here are all my settings:
-virtualdub 1.5.10 video->fast recompress (no filters in use)
- xvid 1.1.0 beta1
- Profile level AS @ L5
Quantization type: H.263
Interlaced Encoding: unchecked
Quarter Pixel: unchecked
Global Motion Compensation: unchecked
B-VOPs: Checked
Max Consecutive VBOPs: 2
Quantizer ratio: 1.50
Quantizer offset: 1.00
Packed bitstream: checked
- encoding type: single pass (settings left on default)
- Zone Options
Start with frame: 0
Weight: 0
Begin with keyframe: Checked
Grayscale Encoding: unchecked
Chroma Optimizer Enabled: Checked
BVOP Sensitivity: 0
- Advanced Options
Motion search precision: 6 - Ultra High
VHQ mode: 1 - Mode Decision (faster) or 4 - Wide Search (best quality - slower)
Use chroma motion: Checked
Turbo : Unchecked
Frame drop ratio: 0
Maximum i-frame interval: 300
Cartoon Mode: checked (I´m encoding an anime)
Min I-frame quantizer: 1
Max I-frame quantizer: 31
Min P-frame quantizer: 1
Max P-frame quantizer: 31
Min B-frame quantizer: 1
Max B-frame quantizer: 31
Trellis quantization: Unchecked
Automatically detect optimizations: Selected
FourCC used: XVID
OutputDebgString debug level: 0x0
Print debug: unchecked
Display Encoding status: Unchecked
In the built in calculator I used the correct settings for target size, frames per second and audio format... which I´m using MP3 codec 128/44800 and my source is an wav file extracted with virtualdub from the original xvid file.
Virtualdub audio is set to full process.
At last... my encoded file size is about 650MB and not the expected 700MB.
thanks for your reply! -
The audio is 128/48kHz
My target bitrate was set as 860 and I just tried Gspot on my encoded file and got 808. Why this bit rate chance? Doesn´t xvid use the target bitrate? Is it related to my zone options? What am I doing wrong?
Hope someone can help me out with this file size issue.
Thanks again.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 16:31 -
Problem with target filesize in xvid
By legion0 in forum Video ConversionReplies: 18Last Post: 21st Mar 2010, 23:58 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
