Currently I import video footage thru FIREWIRE 1394 port in my PC. I edit the footage and have output the footage to TV/Monitor for previews using the DV camera path thru.
Basically the setup is like this:
Capturing.
VHS
DV --> IEEE1394 --> PC
DVD
Output to TV
PC --> IEEE1394 --> DV CAM --> TV/Monitor
I am using PPRO 1.5 and would like to eliminate DV CAM form the output chain.
Basically I want two non-depended ways to capture video and output to TV/Monitor while I am editing.
Please let me know what parts are required and how to set it up.
Thanks.
Try this:
http://www.newegg.com/app/viewproductdesc.asp?description=14-122-180&DEPA=0
It's a TV capture card. That's what I use. There are many choices starting around $30+ Then I use video output from the video card and hook that to the TV via the RCA connections. Works like a charm -
Does it output signal from Premiere Pro?
any help please
Any of the DV capture devices like the Canopus ADVC-100 would allow you to output to a preview monitor from Premiere, however I don't think you can preview it as you're capturing it from a digital source. Perhaps the higher-end ones like the ADVC-500 can do this? Otherwise I just use the S-video out on my video card to output to a TV and just place one of the preview monitors from Premiere into it sized to fit. It isn't quite the same though since it's technically just a resized window so it won't give you a great idea as to where your picture will cut out on a TV but it still gives you the proper color representation. I also use this for Encore to preview the menus and everything for color problems.
FB-DIMM are the real cause of global warming
Connecting DVD with VGA output to computer monitor.
By danyalos in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2009, 12:12 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 07:43 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 15:17 -
No video output on tv monitor
By andrw in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Mar 2008, 03:04 -
Looking for a device to output signal as second (or mirrored) monitor to TV
By ViRaL1 in forum Off topicReplies: 0Last Post: 29th Aug 2007, 11:33
