  1. Hi All
    I have been sent a .bin file & .cue file with instructions to burn them to a DVD, now forgive me if I am wrong but is this not a CD-ROM image type?
    The unstructions state burn them to a DVD usinf Nero.
    Washac
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Yes, the .bin and .cue files are a form of CD image. One contains the data and the other tells the burner how to burn.
    There is no Nero for the Mac, unless you count the crappy NeroMax from about 4 years ago. I'd say burn them with MissingMediaBurner.
  3. I would burn it with Toast6.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Toast = $$$
  5. Hi
    OK, let me try and put this another way.
    I have just read that .bin files can be converted back there origins, if this can be done then maybe I can burn this to a DVD as instructed. The same place says that Toast 5.2 can do this, burn bin to DVD.
    Only read the above saying it can be done, no instruction on how to do it.
    Can this be done either way?
    Washac
