I dl'd a movie [DIVX] that is 25 fps, I want to use TMPGEnc to make it SVCD, burn it with nero and play it on my DVD player (apex de - 660)
Do I encode as PAL or do I need to change it NTSC since I'm in the US?
It would probably be a lot easier to leave as PAL because converting between PAL>NTSC and vice versa can be a right pain because of the audio going out of sync etc. etc.
Try a small test clip on a CDRW (if possible) and see if it works. It really depends on whether your TV can handle PAL and/or whether your DVD player can change the output to NTSC if necessary. In the UK pretty much every DVD player can convert stuff into PAL from NTSC but I don't know if US machines can generally convert stuff into NTSC.
Will a homemade NTSC dvd play on a PAL player?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2010, 03:54 -
AVI file won't play via stand alone DVD player
By 3lutz3toe in forum MacReplies: 2Last Post: 24th Dec 2009, 05:37 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 19:07 -
Can you burn Xvid files to DVD so they will play on stand alone DVD Player?
By JoeBolden in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2007, 16:48 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 16:53
