I am trying to convert a Xvid Avi file/s to burn to DVD, but I keep getting the wrong aspect ratio compared to the original.
I tried the settings DVD ffmpeg / Autosize to DVD 16:9 / Letterbox to 16 16 16 16 but still I get a bit narrower picture.
When I save the Avi file to .Mov and try the same settings with ffmpeg, I get the correct aspect ratio, but picture is darker.
Is there a setting I could use to encode the Avi directly and get the correct aspect ratio of the original?
My Avi source file is:
Format: 640x272
Frame Rate: 23.98
And others with little difference.
What I would do:
NTSC:
Video Size:720x360 letterboxing of: 60,60,0,0
Pal
Video Size:720x432 letterboxing of: 72,72,0,0
(All values divisible by 8 )
DVD ffmpeg, 16:9, decode with quicktime off
Cheers
I found the solution:
Choose DVD ffmpeg, Widescreen 16:9,
Filter Menu:
Letter Box are: 16 16 16 16
Options:
Decode with QuickTime including Letter Box.
Enjoy.
Okay, now what if my source video is identical to yours except it's in PAL format. Can I simply change it NTSC Film? Wil that cause audio sync issues?
Visit me at www.virtualaftershock.com/ for all your Custom DVD cover needs.
Aspect Ratio Problem
By maccool111 in forum Video ConversionReplies: 6Last Post: 29th Mar 2010, 07:58 -
Aspect ratio problem
By nlaak in forum DVD RippingReplies: 6Last Post: 4th May 2009, 16:13 -
By Renegade in forum Video ConversionReplies: 8Last Post: 2nd Mar 2009, 20:04 -
By kewowski in forum MacReplies: 0Last Post: 2nd Feb 2008, 08:38 -
By Derin in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2007, 22:00
