I tried tmp plus, ulead dvd movie factory , and main concept. all have the same problem. it'll convert fine and then just froze. I am trying to convert it to a vcd. it's giving me a continous still frame while the audio keep going. is there anything i can do?
here are some info on that file
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
Maybe something here can help
https://www.videohelp.com/tools?s=12#12Read my blog here.
It's fairly NTSC VCD compliant (the audio sample rate aint right, but it might work anyway) as is, so I'd go ahead and just author it with VCDEasy. That every encoder freezes, indicates that there's something wrong with the mpeg, so it might not play anyway, but it's sure worth a go.
/Mats -
Get VCDGear. Open the mpeg. Select mpeg->mpeg. Click Fix mpeg.
Cheers, Jim
My DVDLab Guides
new videos with silver backings and see threw lettering
By gilly in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 07:25 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
RMVB file won't convert?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 19:34 -
An FLV that just won't convert!
By ker-plop in forum MacReplies: 9Last Post: 17th Dec 2007, 05:17 -
Video won't convert to Widescreen
By RogMcDodge in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 14:46
