Is Asus TV/FM 7135 a good capture card?
I live in US and i have a PAL VCR, can i use the asus card to capture it?
Asus uses philips chip.
Which chips is better Conexant CX23883 or PHILIPS SAA7135HL decorder
chips???
Which one produce better picture and sound?
Which one is more CPU intensitive?
If asus is not the best, please recommend a capture card for me.
My budget is around $60.
Thanks!
I know many people will argue the Conexant is the better chip. I doubt you're going to get a good mpeg-2 hardware capture card for $60 though...
The Asus you mention does not do hardware encoding.
If you have a lot of VHS transfer to do, something like the Canopus ADVC-100 would be better.
If that's way beyond your budget, try and find a card with the Conexant BT8x8 chip. Compatible with a ton of software and 3rd party support.Cheers, Jim
My DVDLab Guides
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
A good Mic, Capture Card, and Video Editing Software.
By xSyndromex in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2010, 14:38 -
Once again - Good capture card for beginner
By MillowQc in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2009, 22:14 -
Good Card for Video Game capture
By npsken in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2007, 07:55 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 06:55
