I get this every time I reboot my 2nd computer. I started to happen when I removed the VIA motherboard with Intel Celeron, and replaced it with newer VIA with AMD+ CPU.
Same situation as this guy:
http://www.ntcompatible.com/thread20016-1.html
System works fine. No issues at all.
50-50 variation in startup screens:
1) Halts on blue intro screen ... I have to hit CTRL+ALT+DEL .. the NT logon keys ... to start it. No error message. Boots into Windows XP Pro as soon as I hit the keys
2) The "page file" warning. I click ok, it boots fine.
Not a huge aggravation ... just a stupid error.
Ideas?
Results 1 to 16 of 16
I don't have tons of stuff installed on my system, but I don't generally recommend a transplant like that without a reinstall. I'd suggest removing the paging file altogether and creating a new one if you haven't already.
Nothing can stop me now, 'cause I don't care anymore. -
virtual memory is probably set too low
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Yep,Originally Posted by glockjs
You just need to expand the limits of the virtual mamory.
None of that works... tried all that long ago.
What worked for me for that specific problem: FDISK /mbr
/mbr is an "undocumented" switch. It won't mess with the contents of your hard drive. Obviously, back up any critical data, but I've never suffered any data loss by running that command.
You'll have to run it from a DOS floppy or bootable CD. -
Hmm.
All that does is rewrite the master boot record (MBR). I doubt it will fix a virtual mem error.
I usually change the settings to manual, set a swap of about 768 max and min, on a different drive.
Restart as prompted, then if necessary, change it back to Windows managed, or whatever.Cheers, Jim
My DVDLab Guides -
I understand the doubt that the FDISK /mbr command will fix the problem. I swear it worked when I ran into that issue. If you run out of ideas, try it.
It would be interesting if that worked. It makes no logical sense, but this IS a computer with Windows that we're talking about
Cheers, Jim
My DVDLab Guides -
Just remember that computers are psychotic, and you will be okay. I agree that rewriting the master boot record doesn't make sense, but stranger things have happened.Originally Posted by reboot
There's always the backup/format/reinstall option.
I just assume click "OK" or press CTRL_ALT_DEL each time. 8)Originally Posted by ViRaL1Want my help? Ask here! (not via PM!)
You MAY be able to use the AutoAdminLogin registry hack (check M$ support site) to avoid having to do the CTRL ALT DEL thing. My suggestion of reinstalling isn't just to avoid the annoyance, it sounds like a signal that something is wrong, maybe something small, but you won't know for sure until the OS goes belly up. :S
Nothing wrong so far, been like this for maybe 6 months now.
How to make a small file with videodub?
By benvid in forum Video ConversionReplies: 5Last Post: 22nd Feb 2010, 08:42 -
How to go from DVD to small MPEG file
By jester805 in forum Newbie / General discussionsReplies: 10Last Post: 17th Oct 2008, 20:15 -
Can a QT file get as small as a WMV?
By Antoniola in forum MacReplies: 6Last Post: 22nd May 2008, 01:13 -
Paging File?
By CSULB71 in forum ComputerReplies: 5Last Post: 29th Apr 2008, 15:28 -
paging SatStorm, rmPAL filter crashing VirtualDub
By friendly_jacek in forum RestorationReplies: 1Last Post: 9th Jan 2008, 23:18
