I have been getting errors with Sizzle saying that the audio encoded with ffmpegx was not the correct sample rate (48 khz) and that it could cause syncing errors (which it does after I build the disk image). I get this same error whether I used the muxed file (.mpg) or the elementary streams. The audio is definitley being encoded to mpeg2 and VLC plays it fine. When I load the .ac3 back into ffmpegx (in the first 'LCD' window), it reads the file as being 48000 hz. Has anyone else had problems along these lines and if so, is there anything I can do?
Something ive noticed: Quicktime does not play the audio in playback, but it does play the video - however, I attribute this to the fact that although I have the mpeg2 component, the AC3 codec only works for AVIs; which may or may not be right.
Thanks in advance.
Note: Im posting this question in this forum mainly because I am inquiring as to any reason the audio may not be encoding correctly in ffmpegx, thanks.
Edit: Im using ffmpegx 0.0.9s and sizzle 0.5b2. Ive read elswhere that this error seems to happen in 0.5b2 so I downloaded 0.5b1. Although the error message does not appear - the audio syncing still gets screwy on the final product.
Results 1 to 1 of 1
Video encoded with VC-1 WMV3 problems
By namenone in forum Newbie / General discussionsReplies: 8Last Post: 16th Feb 2012, 19:15 -
encoded video problems?
By mrjust in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2009, 15:11 -
Megui, some problems withe encoded result
By boy69 in forum Blu-ray RippingReplies: 6Last Post: 30th Sep 2008, 18:16 -
DV encoded Sound Problems
By zack28 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Sep 2007, 19:20 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00
