Hi,
I hope somebody out there can englithen me on this.
I m using both TPMGenc and Mainconcept MPEG Encoder to convert my AVI file to mpeg.
I know that most of the advice given here preferred to use TPMGenc.
But i got one problem, i noticed that mpeg converted using TPMGenc tend to be big - more than 750mb compared to Mainconcept MPEG Encoder.
For eg, for one of the AVI file i tested. TPMGenc's conversion of mpeg file read as 788mb but Mainconcept MPEG Encoder only need 450mb.
Why the different, for each conversion i adopt the default settings. upon testing, quality of the video seems to be the same.
This give me problem as i only want to burn it to VCD in one CD.
Please help.
Being as they are both starting with the same source file and ending with the same product, IE, a MPEG-1 file, then the settings must be different.
Make sure the audio is the same format on both. The bitrate should be 1150 for MPEG-1, but the audio on one may be PCM and the other
MPEG-1 Layer2.
I'm sure there will always be some difference in file size between the two encoders, but not that much. The default settings are probably different.
AVIcodec or Gspot may show you what the difference is between the two files.
EDIT: If you were converting to MPEG-2, I would say TMPGEnc was trying to use all the available room on the CD by upping the bitrate to fill the space. But the bitrate is usually fixed on MPEG-1 VCDs to 1150 to be compliant. -
Given all else being the same, Mainconcept will do it in half the time (or less).
Cheers, Jim
My DVDLab Guides
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 04:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 21:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 16:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 20:06
