Hi there, bought the software on recomendation of a friend. I think the software itself is great and easy to use but it has not worked once for me. Without fail I get an error message. I've searched the forums as to why this is happening and I can't seem to find the answer. Keep in mind, I'm not computer genius so this is becoming highly frustrating. As of yet I have not been able to burn one single DVD. The problem is that this error message pops up every single time that the program is about to start the encoding menu process. Below is the message that keeps popping up:
Version:SVCD2DVD 2.0 RC4
Type: System.ArgumentException
Source: mscorlib
Message: The path is not of a legal form.
InnerException:
StackTrace: at System.IO.Path.nGetFullPathHelper(String path, Char[] invalidPathChars, Char[] whitespaceChars, Char directorySeparator, Char altDirectorySeparator, Char volumeSeparator, Boolean fullCheck, String& newPath)
at System.IO.Path.GetFullPathInternal(String path)
at System.IO.FileInfo..ctor(String fileName)
at x3284ccece41ee22b.xece14591aa1abb99..ctor(Guid xe423f530b92aa05c, String xd168ac2ed64c4662)
at x3284ccece41ee22b.xece14591aa1abb99..ctor(String xd168ac2ed64c4662)
at x3284ccece41ee22b.xd3764d4f1e921081.x4f3432523597d cf6(Boolean x7ce1fdb24a74c398)
at x3284ccece41ee22b.xd3764d4f1e921081.xa727fa5530af9 286()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
Could you please tell me what to do so that I don't feel like I bought this thing for nothing. Thanks in advance for your help!
Results 1 to 12 of 12
OK, so I tried the new version but another problem arose: it goes all the way to 'done: burning DVD folder' but then it doesn't burn (even though I have Nero 6 and everything seems to be configured correctly). then if I try to do it manually by dragging the supposedly completed svcd2dvd_output file into Nero myself, I get an error message when I try to burn: Compliance test failed, required files: video_ts.info not present & video_ts.bup not present.
Anyone have any idea whats going on here? Like I mentioned in my first post, my computer knowledge is rather limited so I'm begining to get frustrated...please help! thanks!! -
Did you get the NeroBurner window in the middle of SVCD2DVD? If so were there any messages in there?
What is the contents of the VIDEO_TS folder under the SVCD2DVD_OUTPUT folder?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi,
Yes, there was a white window that opened after the d'one:burning DVD folder' but it didn't do anything. its as though it froze...maybe I was out of space on my drive? as for the contents of the folder, I deleted it so I cant say. I will try taking things off my drive and trying again. The whole process always takes about 3 hours so it takes so long to find out if it will work or not. I will repost to let you know what happens this time. Hopefully this can be cleared up. Thanks! -
Ok, still not working. Getting very frustrated here...I've had this software for a week now and it hasn't worked at all. Here is the latest error message:
Source: mscorlib
InnerException:
This appears as it the program attempts to encode the menu. Please help me fix this so I can actually use this program. Thanks. -
Can you ensure that the menu audio is set correctly in the menu settings? Choose silience of if custom, make sure the file exists.
OK, will try that. Which one should I use, Mpeg silence or AC-3 silence? I'm in Canada if that makes some sort of regional difference. THanks!
Ok, I'm just about ready to give up on this thing. Here is the error message I just got as it was trying to encode the menu:
Version:SVCD2DVD 2.0 RC5
Source: mscorlib
InnerException:
My settings are as follows:
Process settings: standard/fullscreen & widescreen TV, convert PAL assets to NTSC, AC-3 audio, chapter frequency every 1mins
Menu: Silence (AC-3 Audio) [this is because I have no audio for this particular menu], NSTC Menu
Burning: NeroBurner, DVD RW DW etc...
What is going on here? Why is this not working? It keeps taking me 4 hours before I can find out that it isn't working so it's getting highly frustrating. Please help!!! -
And for the record, the contents of the SCD2DVD output file are as follows (in this particular case I have 4 assets):
audio TS: empty
video TS:
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_0.VOB
VTS_01_1.VOB
VTS_01_2.VOB
VTS_02_0.IFO
VTS_02_0.BUP
VTS_02_0.VOB
VTS_02_1.VOB
VTS_02_2.VOB
VTS_03_0.BUP
VTS_03_0.VOB
VTS_03_0.IFO
VTS_03_1.VOB
VTS_03.2.VOB
VTS_04_0.IFO
VTS_04_0.BUP
VTS_04_0.VOB
VTS_04_1.VOB
VTS_04_2.VOB -
I think i see what the issue is. Drop me an email & i will send you a build with a fix.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 20:13
